Starting Issues
Vinni
I didn't do it
Helotes, TX
I gonna piggy back on this thread if you don't mind.
I have had a CEL (check engine light) on for the past 4 months or so. Had the codes read by a friend of mine with a power programmer. Sayz the GLow Plug Ralay bank is bad (forget the actual code).
I talked with a Ford mechanic the other day at my local dealership here in Del Rio - he claims the PSD has 2 relays for the GPs - Correct???
A while back, i bought a GPR on EbaY and went to switch it out, the mount ears do not match up with the OEM GPR. It has the two small posts and the two large posts; however they are not in the same configuration as the OEM.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33693&viewitem=&item=320041668428
What about this one:
http://k-mansparts.com/browse_item_details.asp/Item_ID/317501
Is there a way to ohm out the relays in order to ensure i hook it up properly as apposed to trial and error and possibly frying the relay or some wiring?
Correct me if i am wrong, but the GPR sits on the passenger side of the fuel bowl - in the front position next to the AIH relay???
TIA
