serpentine belt
Kleetus
Butler PA
I hope the water pump is still turning the same direction as before... It's odd that the belt diagram wasn't the way the belt was routed.
HeavyAssault
King William, VA
Drain a gallon of coolant from the radiator. Disconnect the radiator hoses on the driver's side, then remove the secondary shroud (w/ the PSD badge). It will pull out with some help. I used a braker bar on the tensioner to get the belt off. Follow the diagram for the routing of the new belt. Return truck back to stock, start and run till at operating temps, check for leaks at the hoses. Test drive to ensure everything is OK, check belt condition and hoses for leaks on shutdown. Have a beer knowing you did a great job.
FlorWhitfe
