Folks, I am new to the forum and I am in need of some guidance.
My truck is an 04 F250 4x4 with the 6.0L Powerstroke.
My serpentine belt is squealing and is quite annoying. I purhcased a new belt with the intentions of installing it over the weekend, but once I started tearing into the project I am stumped.
My truck has the single alternator set up for reference.
I can not figure out how to get the radiator and shroud out to get the belt replaced.
I removed the small shroud on top of the radiator shroud as well as the Power Stroke emblem cover. I also removed the two bolts in the top of the shroud, but I cannot figure out how it comes out. Initially, I thought the shroud was a two piece design, but after further inspection it is not. I looks like the finned portion of the shroud around the fan bolts to front of the engine block.
I cant get to the tensioner pulley with the shroud on to release the tension on the belt, so I wondered if I can take the alternator loose and get the belt off, then work it out between the round hole in the finned shroud and the fan hub and then over the fan and out through the hole in the shroud below the Power Stroke cover.
Does anyone have any experience at this that could give me a step by step process to replace the belt? I am not paying the dealer $225 to replace the belt. I am mechanically inclined and will eventually figure it out, but any help would greatly be appreciated!
Thanks,
SBW
Thanks,
SBW
