seems like it is losing coolant
shelby69
west bend / wi
Brother in law has a 2005 diesel truck and he has issues with the interior heat.
About 2 months ago, I suggested the first thing is to check and make sure the coolant level is correct. He said it was low, maybe took 2 quarts.
It seems as if we figured out when it puts out heat, only when you floor it to high r's, I have different thread to address why this could be.
Today, about 2 months after he added coolant, we took a look to figure out why he gets very little interior heat and when he went to let the pressure out of the coolant system, he noticed that is fill tank was empty. The system is pressurizing and I did get coolant out of the heater hoses.
My question to the group is, how does one verify if his truck is eating or leaking coolant?
THanks
SAS
no-red 6 0
Senioritis
southmetro MN
where is the truck?
what does the exhaust 'look/smell' like...-color?
i along w/ others prolly have the same hunch-----------head gasket problem!!!:sorry
mrpowerstrokeman
northwest
pull your egr valve out if there is coolant in the intake you need a egr cooler and probably an oil cooler. if dry you need headgaskets!!
my05psd
woodsy
fort mcmurray ,alberta
coolent lost
my truck seems to have the same symptoms. i lose heat just once in a while when i slow down.was wondering, does your truck seem like it takes longer to start then it should. mine rolls over always 3 or 4 times before it starts. :dunno i also have had to add coolant twice recently.stock besides sct with street tune from innovative.
TacoCat
