Remote Start
Dieselmech
Has anyone put a remote starter on a powerstroke, or can it be done. I know it wont run the glow plugs before it started but theres got to be a way so it will. Use to have one on my camaro and used it all the time in the winter.
RoReRi
Verona, NC
Yes they will work and burn the glow plugs for a predetermined time before actually kranking her up. Just go to a reputable alarm installer they will Hook you up...
Good Luck
RoReRi
Dieselmech
good deal, thankyou. I guess I need to do some research now to see how to do it. Try no to take my truck in whenever possible, to expensive. But thats good to hear
pete37922
JERZY
yeah, there were a couple guys i knew in school that had remote starts on thier trucks...they were on powerstrokes and i knew another kid that had it on a dodge wit a cummins engine...i dont kno if they have 2 wait 4 thier pre-heaters or not !!!
RoReRi
Verona, NC
You can go by the alarm places, and find out which ones would work for you, THEN, if you are a DIYer then you can find one on Ebay or the internet stores for less and install it yourself;) ;) :cool:
Good Luck
RoReRi
I installed my own UltraStart remote start and it can be set to heat the glow plugs for a set amount of time or it can be set to start when the wait light goes out. I have mine set for twelve seconds as when I use it the temp is usually well below zero and I like the extra heat time. The systems are actually easy to install they just take some time if you want to do a real clean job. I think I spent around six or eight hours on mine but it looks like a factory installation.
Skram
