Regearing the rear end
chief2
Bunnell,Fla.
I have been looking at regearing the rear from 4:88's to a 4:10. Got some good info here and finally found someone to do the job. He has a good rep. and is wanting $1,500.00 to get it done. New Ring and Pinion, Carrier, Bearings and Pinion Seal. R & R included. Does this sound like a good price?
Elk
Colorado
Which brand of gears will be installed? Make sure you get a quality set. Around here (Norther Colorado) I can get gears installed at a reputable shop ~$300 labor.
paulkeith
Da A
how much of that is parts, and how much is labor? i'd say about ~$500 labor is the max you want to do, and if he's charging you $1000 in parts for a common ratio on ONE axle....i'd look for a new shop.
Paul
chief2
Bunnell,Fla.
Wow, he tells me it is expensive because he also has to chage the carrier. He is also the only game in town with a good reputation. I hope I'm not getting screwed!
Race22
Jim
Moore Okla
I don't see what the carrier has to do with the rear end unless it is bad and really does need to be changed. I had 4:10 put in another truck, F-150, and it only cost me $1000. He seams a little high to me.
Some of the carriers need to be changed if the ratios are too far apart. I don't know about the Ford ratios, but Jeeps need to change the carrier if you go from 5:38 to 4:10's. At least the early Jeeps did (1946 CJ-2A).
paulkeith
Da A
ok, that might make a little more sense. carriers do have to change with certain ratio changes because the thickness of the ring gear will change a certain amount, to the point where the right ring gera is either too thick or too thin.
i'm not sure on the price of a carrier, but they shouldn't be too expensive. If this guy is your only option, and he's reputable, and you have the coin.... go for it.
chief2
Bunnell,Fla.
He is telling me that the Ring Gear is riveted to the carrier that is why it has to be replaced.
XTrmXJ
NACHHOOOOOOO!!!!
Hampton Va
On avarage the going price is $400 labor per axle if its on the truck, if the axle was removed it would be cheaper.
Gears just for the rear axle from the internet 4.10 $513
Master instal kit $191
carrier $???
rear axle setup $400
so its just for the rear axle $1104 + carrier price, before taxes and before hazmat, disposal fees ..... Now is yours 4wd, if it is then $1500 for both axles are a good deal, I also based this off a sterling 10.5
Brad1103
