ReBuilding Injectors
bigdiesel99
corinth texas
I am sure you will love them, adn the turbo will work well with them:sweet , I personally use the Turbonetics stock replacment with a 91mm compressor wheel, keep us all updated on the results-popcorn ...
Happy wrenching
high_tech_redneck
If you go with Swamps, you will love them, noone in the field is as good with the Ford powerstroke Systems. I've been to their shop and seen them in action, and lemme tell you what, when they build you a set of injectors they bench flow test every injector, and make sure it flows what it is suppossed to and that they all flow the same amount
FlorWhitfe
