REAR END FLUID EVERY WHERE
F-450 HOTSHOT
I took my 99 F-450 on a run earlier today about 350 miles. It has been leaking a little fluid from the front seal on the rear end for a few weaks now but not that bad. After i would park it would leave about a quarter size puddle on the floor. But this time when i got back from the run there was fluid every where. All over the rear end, the diesel tank the bottom of the bed, every where. Could this be from that front seal leaking or do I got other problems.
Thanks ahead of time.
Northeast Texas
input seals are a piece of cake to change... provided you got a serious arm on yoou to undo the pinion nut.
my 02 took the tech less than hr to change all three times....
its critical it go in square to the housing and well lubed.
parts are under 40 buckarooos
unless you have to change out the pinion shaft
good luck
hello, i was just wondering what kind of freight do you hot shot around?
and what region of the country do you haul in?
im a car hauler myself here in the southeast.
welcome and hope the :bootyshak leak will not be anything bad.
TacoCat
