superdub01
SDD USMC/Wyotech
first, the problem: for the FIRST START of the day the truck will crank fine but will not fire, unless the block heater is plugged in for at least two hours. (regardless of the temperature. it was 60 degrees today) if i try to start it without being plugged in, even cycling the glow plugs multiple times, during cranking, it will fire a little, then die, then fire a little, then die. almost like a gas engine way out of timing. i have gotten lucky a few times and it eventually started, but ran extremely rough (like on 5 cylinders and no power) until i drove and applied 3/4 to full throttle. then it would spontaneously fire all cylinders and run great. for the rest of the day all startups are normal, power is normal, smoke is normal. it has wait to start light, oil pressure, and the tac moves while cranking.
truck has a new GPR and new glow plugs. oil level is fine, however i havent checked the HPOP level because i dont know how to. while the valve covers were off, i cycled the glow plugs and verified that they were all glowing and they all passed the resistance checks.
i'm totally stumped. thanks in advance fellas
