Question to the IT department
Maxtor
Redding
If you are familiar with wsping pro pack, I see numerous time outs when using throughput. Most problems are changing from one web page to another. Slow to time outs. This only happens on this website. No problems on the others I use. Also this problem is sporadic. Could be a router problem. Average ping times now are in the 85 ms bracket.
Big K
SDD.com Hacker/Admin
Dallas, Texas
Yeap, I have used it before and many other programs in the past.
I just loaded up WS_PING for ya at home here.
Here is a few tests I ran ;)
Check superdutydiesel.com 50/1024/1000/1000; Start time 12/10/07 21:02:45
Pkt:1 Sent: 56 B Rec: 56 B Time: 25.08 Throughput: 35.84 kilobits/sec
Pkt:2 Sent: 76 B Rec: 76 B Time: 30.02 Throughput: 40.53 kilobits/sec
Pkt:3 Sent: 96 B Rec: 96 B Time: 25.02 Throughput: 61.44 kilobits/sec
Pkt:4 Sent: 116 B Rec: 116 B Time: 26.06 Throughput: 71.38 kilobits/sec
Pkt:5 Sent: 136 B Rec: 136 B Time: 27.05 Throughput: 80.59 kilobits/sec
Pkt:6 Sent: 156 B Rec: 156 B Time: 26.02 Throughput: 96.00 kilobits/sec
Pkt:7 Sent: 176 B Rec: 176 B Time: 26.08 Throughput: 108.30 kilobits/sec
Pkt:8 Sent: 196 B Rec: 196 B Time: 30.09 Throughput: 104.53 kilobits/sec
Pkt:9 Sent: 216 B Rec: 216 B Time: 26.02 Throughput: 132.92 kilobits/sec
Pkt:10 Sent: 236 B Rec: 236 B Time: 31.05 Throughput: 121.80 kilobits/sec
Pkt:11 Sent: 256 B Rec: 256 B Time: 26.05 Throughput: 157.53 kilobits/sec
Pkt:12 Sent: 276 B Rec: 276 B Time: 27.02 Throughput: 163.55 kilobits/sec
Pkt:13 Sent: 296 B Rec: 296 B Time: 26.05 Throughput: 182.15 kilobits/sec
Pkt:14 Sent: 316 B Rec: 316 B Time: 32.00 Throughput: 158.00 kilobits/sec
Pkt:15 Sent: 336 B Rec: 336 B Time: 28.07 Throughput: 192.00 kilobits/sec
Pkt:16 Sent: 356 B Rec: 356 B Time: 38.03 Throughput: 149.89 kilobits/sec
Pkt:17 Sent: 376 B Rec: 376 B Time: 29.00 Throughput: 207.44 kilobits/sec
Pkt:18 Sent: 396 B Rec: 396 B Time: 27.06 Throughput: 234.66 kilobits/sec
Pkt:19 Sent: 416 B Rec: 416 B Time: 29.01 Throughput: 229.51 kilobits/sec
Pkt:20 Sent: 436 B Rec: 436 B Time: 27.05 Throughput: 258.37 kilobits/sec
Pkt:21 Sent: 456 B Rec: 456 B Time: 27.07 Throughput: 270.22 kilobits/sec
Pkt:22 Sent: 476 B Rec: 476 B Time: 27.00 Throughput: 282.07 kilobits/sec
Pkt:23 Sent: 496 B Rec: 496 B Time: 27.03 Throughput: 293.92 kilobits/sec
Pkt:24 Sent: 516 B Rec: 516 B Time: 27.00 Throughput: 305.77 kilobits/sec
Pkt:25 Sent: 536 B Rec: 536 B Time: 29.08 Throughput: 295.72 kilobits/sec
Pkt:26 Sent: 556 B Rec: 556 B Time: 27.06 Throughput: 329.48 kilobits/sec
Pkt:27 Sent: 576 B Rec: 576 B Time: 29.02 Throughput: 317.79 kilobits/sec
Pkt:28 Sent: 596 B Rec: 596 B Time: 33.00 Throughput: 288.96 kilobits/sec
Pkt:29 Sent: 616 B Rec: 616 B Time: 29.07 Throughput: 339.86 kilobits/sec
Pkt:30 Sent: 636 B Rec: 636 B Time: 34.03 Throughput: 299.29 kilobits/sec
Pkt:31 Sent: 656 B Rec: 656 B Time: 30.02 Throughput: 349.86 kilobits/sec
Pkt:32 Sent: 676 B Rec: 676 B Time: 28.04 Throughput: 386.28 kilobits/sec
Pkt:33 Sent: 696 B Rec: 696 B Time: 30.05 Throughput: 371.20 kilobits/sec
Pkt:34 Sent: 716 B Rec: 716 B Time: 29.05 Throughput: 395.03 kilobits/sec
Pkt:35 Sent: 736 B Rec: 736 B Time: 29.02 Throughput: 406.06 kilobits/sec
Pkt:36 Sent: 756 B Rec: 756 B Time: 29.04 Throughput: 417.10 kilobits/sec
Pkt:37 Sent: 776 B Rec: 776 B Time: 31.00 Throughput: 400.51 kilobits/sec
Pkt:38 Sent: 796 B Rec: 796 B Time: 30.08 Throughput: 424.53 kilobits/sec
Pkt:39 Sent: 816 B Rec: 816 B Time: 32.00 Throughput: 408.00 kilobits/sec
Pkt:40 Sent: 836 B Rec: 836 B Time: 29.06 Throughput: 461.24 kilobits/sec
Pkt:41 Sent: 856 B Rec: 856 B Time: 29.06 Throughput: 472.27 kilobits/sec
Pkt:42 Sent: 876 B Rec: 876 B Time: 30.04 Throughput: 467.20 kilobits/sec
Pkt:43 Sent: 896 B Rec: 896 B Time: 31.04 Throughput: 462.45 kilobits/sec
Pkt:44 Sent: 916 B Rec: 916 B Time: 31.09 Throughput: 472.77 kilobits/sec
Pkt:45 Sent: 936 B Rec: 936 B Time: 31.05 Throughput: 483.09 kilobits/sec
Pkt:46 Sent: 956 B Rec: 956 B Time: 30.04 Throughput: 509.86 kilobits/sec
Pkt:47 Sent: 976 B Rec: 976 B Time: 35.01 Throughput: 446.17 kilobits/sec
Pkt:48 Sent: 996 B Rec: 996 B Time: 36.05 Throughput: 442.66 kilobits/sec
Pkt:49 Sent: 1016 B Rec: 1016 B Time: 37.05 Throughput: 439.35 kilobits/sec
Pkt:50 Sent: 1024 B Rec: 1024 B Time: 30.07 Throughput: 546.13 kilobits/sec
End time 12/10/07 21:03:36
50 packets, 54576 bytes in 1491 ms. average:292.82 kilobits/sec median:299.29 kilobits/sec
At home, the pings aren't as good as at work though ;)
Ping superdutydiesel.com 20/5000/56/1; Start time 12/10/07 21:04:36
ping 74.53.243.98 packet 1 round trip time = 24 ms. successful
ping 74.53.243.98 packet 2 round trip time = 25 ms. successful
ping 74.53.243.98 packet 3 round trip time = 24 ms. successful
ping 74.53.243.98 packet 4 round trip time = 24 ms. successful
ping 74.53.243.98 packet 5 round trip time = 26 ms. successful
ping 74.53.243.98 packet 6 round trip time = 24 ms. successful
ping 74.53.243.98 packet 7 round trip time = 25 ms. successful
ping 74.53.243.98 packet 8 round trip time = 27 ms. successful
ping 74.53.243.98 packet 9 round trip time = 34 ms. successful
ping 74.53.243.98 packet 10 round trip time = 25 ms. successful
ping 74.53.243.98 packet 11 round trip time = 24 ms. successful
ping 74.53.243.98 packet 12 round trip time = 27 ms. successful
ping 74.53.243.98 packet 13 round trip time = 28 ms. successful
ping 74.53.243.98 packet 14 round trip time = 25 ms. successful
ping 74.53.243.98 packet 15 round trip time = 28 ms. successful
ping 74.53.243.98 packet 16 round trip time = 24 ms. successful
ping 74.53.243.98 packet 17 round trip time = 26 ms. successful
ping 74.53.243.98 packet 18 round trip time = 25 ms. successful
ping 74.53.243.98 packet 19 round trip time = 24 ms. successful
ping 74.53.243.98 packet 20 round trip time = 30 ms. successful
20 packets sent; 20 packets received; 0% lost.
Round trip times (ms): Minimum: 24, Maximum: 34, Average: 25
End time 12/10/07 21:04:57
Maxtor
Redding
Here are a few from here.
Check www.powerstrokediesel.com 50/1024/1000/1000; Start time 12/10/07 20:56:57
Pkt:1 Sent: 56 B Rec: 56 B Time: 86.02 Throughput: 10.41 kilobits/sec
Pkt:2 Sent: 76 B Rec: 76 B Time: 86.00 Throughput: 14.13 kilobits/sec
Pkt:3 Sent: 96 B Rec: 96 B Time: 86.07 Throughput: 17.86 kilobits/sec
Pkt:4 Sent: 116 B Rec: 116 B Time: 86.05 Throughput: 21.58 kilobits/sec
Pkt:5 Sent: 136 B Rec: 136 B Time: 85.06 Throughput: 25.60 kilobits/sec
Pkt:6 Sent: 156 B Rec: 156 B Time: 99.06 Throughput: 25.21 kilobits/sec
Pkt:7 Sent: 176 B Rec: 176 B Time: 87.01 Throughput: 32.36 kilobits/sec
Pkt:8 Sent: 196 B Rec: 196 B Time: 87.04 Throughput: 36.04 kilobits/sec
Pkt:9 Sent: 216 B Rec: 216 B Time: 89.06 Throughput: 38.83 kilobits/sec
Pkt:10 Sent: 236 B Rec: 236 B Time: 87.04 Throughput: 43.40 kilobits/sec
Pkt:11 Sent: 256 B Rec: 256 B Time: 90.08 Throughput: 45.51 kilobits/sec
Pkt:12 Sent: 276 B Rec: 276 B Time: 90.04 Throughput: 49.06 kilobits/sec
Pkt:13 Sent: 296 B Rec: 296 B Time: 89.08 Throughput: 53.21 kilobits/sec
Pkt:14 Sent: 316 B Rec: 316 B Time: 92.03 Throughput: 54.95 kilobits/sec
Pkt:15 Sent: 336 B Rec: 336 B Time: 90.07 Throughput: 59.73 kilobits/sec
Pkt:16 Sent: 356 B Rec: 356 B Time: 91.00 Throughput: 62.59 kilobits/sec
Pkt:17 Sent: 376 B Rec: 376 B Time: 90.03 Throughput: 66.84 kilobits/sec
Pkt:18 Sent: 396 B Rec: 396 B Time: 88.08 Throughput: 72.00 kilobits/sec
Pkt:19 Sent: 416 B Rec: 416 B Time: 94.02 Throughput: 70.80 kilobits/sec
Pkt:20 Sent: 436 B Rec: 436 B Time: 92.09 Throughput: 75.82 kilobits/sec
Pkt:21 Sent: 456 B Rec: 456 B Time: 92.05 Throughput: 79.30 kilobits/sec
Pkt:22 Sent: 476 B Rec: 476 B Time: 93.03 Throughput: 81.89 kilobits/sec
Pkt:23 Sent: 496 B Rec: 496 B Time: 93.08 Throughput: 85.33 kilobits/sec
recv error Timed Out
Pkt:24 Sent: 536 B Rec: 536 B Time: 92.00 Throughput: 93.21 kilobits/sec
Pkt:25 Sent: 576 B Rec: 576 B Time: 94.00 Throughput: 98.04 kilobits/sec
Pkt:26 Sent: 616 B Rec: 616 B Time: 93.01 Throughput: 105.97 kilobits/sec
Pkt:27 Sent: 636 B Rec: 636 B Time: 96.00 Throughput: 106.00 kilobits/sec
Pkt:28 Sent: 656 B Rec: 656 B Time: 95.02 Throughput: 110.48 kilobits/sec
Pkt:29 Sent: 676 B Rec: 676 B Time: 94.03 Throughput: 115.06 kilobits/sec
Pkt:30 Sent: 696 B Rec: 696 B Time: 95.05 Throughput: 117.22 kilobits/sec
Pkt:31 Sent: 716 B Rec: 716 B Time: 96.05 Throughput: 119.33 kilobits/sec
Pkt:32 Sent: 736 B Rec: 736 B Time: 94.01 Throughput: 125.27 kilobits/sec
Pkt:33 Sent: 756 B Rec: 756 B Time: 97.04 Throughput: 124.70 kilobits/sec
End time 12/10/07 20:57:45
33 packets, 25896 bytes in 3022 ms. average:68.55 kilobits/sec median:66.84 kilobits/sec
johnrrogers
Old Racer
Chula Vista CA
I just pinged the site here and averaged 43ms over several tries. When I open a new screen on this site it comes up nearly instantaneous? I have a 64bit dual core CPU and 4GB of RAM and a new Nvidia video card so most everything displays pretty fast.
I have been noting definite slowdowns to timeouts from our computers as well,seems kinda trendy-popcorn
Big K
Dallas, Texas
I have yet to see any besides the apache issues we had the other day when it wouldn't come up at all.
tonkadoctor
Autryville, NC
I'm retired and surf the net a good portion of the day to break up the boredom, I pop in here to browse or lurk many times a day. This site and the oilburners site have the slowest loading pages of any I visit regularly throughout the day.
I don't have the blazing fast connections most do, I'm on 768k DSL and it's definatly noticable.
And my puter isn't exactly a slouch either and I keep the software up to date with one exeption. I run IE6, I don't like 7 right now.
  • athlon xp 3400+ 400 FSB Barton core
  • epox 8RDA3+ dual DDR motherboard
  • 1 gig PC3200 dual DDR ram (2 x 512 matched)
  • two Seagate barracuda 160 gig SATA hard drives in RAID stripped configuration
  • ATI Radeon X800 PRO AGP video card w/ 256mb GDDR3 ram
  • Windows XP pro with all settings on performance, not looks.
  • Zone alarm firewall... windows is off
  • AVG anti virus
  • NoAds pop up blocker.. windows shut off
Maxtor
Redding
why are you testing powerstrokediesel.com?????
Duh....:innocent
Old age, bad eyes, senility, take your pick. :dunno
I'll run a test on superdutydiesel tonight. Got to run to another doctors visit this morning.
:doh:
cityworldford
