Power Steering system flush,1 person?
To my knowledge all 1999-2003 7.3L powerstrokes came with ATF for use in the Power steering system.
very interesting! learn something new everyday:sweet
I too was surprised to learn that ATF was used when we took delivery of our 99 which made things simplified as I didn't need to stock separate power steering fluid.sweet
platinum01
Willis, TX
very intresting guess it is time to start do some service on the truck now. That is very intresting about the atf in the ps pump.
transmission fluid is the recommended fluid for Powerstrokes..
About half of the vehicles we service specify ATF, the other half some form of the clear
is atf used for the brakes as well or do you still use brake fluid for that?
The brake system requires "DOT 3" brake fluid.
iracemine
black and tan
Cheese Curtain
So I did this today. I found if you slam on the brake and keep the wheel pegged the fluid shoots out. However a little to fast, I got air into the pump. So I just shut the motor off and then just turned the wheel back and forth a few times and the air got out. Then I got about 3 quarts through and the fluid was nice and red not black like it started.
Oh, the one thing I did differently was I sucked all the old fluid out of the reservoir first and then refiled it with fresh before I started this.
P.S. I found this thread through the search function on this site. This place is awesome! Thank you to all who help and give moneys!!!!:clap:
Jriltex
