Power steering hissing
sagebel
Stock? Pfft!
Albuquerque, NM
This truck is really starting to test me this holiday season. Still have the mystery vibration/shudder. Water pump is leaking, tensioner is whining and on the way to the parts store the power steering was making a hissing sound. Is this hissing a sign that I need a new PS pump? Are there any specail tools needed to do the job?
Scott
drmjf
Pinole, Kalifornia
How's the fluid level? If it's low you have a air in the system. It requires that a vacuum of about 2-3 inches be placed on the power steering pump, to remove the air in the system. You need to let the truck idle while keeping the vacuum. It takes about 5-10 minutes. Hope this helps.
was it hissing or moaning?
a hiss would be fluid running through the pressure relief valve in the pump.. may or may not indicate problems..
a moan would be air in the system, or fluid cavitation in the pump..
speaking of hissing & moaning..
here's a video for ya..
http://www.youtube.com/watch?v=R3TFm5Epiww
sagebel
Stock? Pfft!
Albuquerque, NM
Hissing. Normally heard at full lock. Now heard whenever the wheel is turned, even at high idle (1250 rpm).
Kinda sounds like a PS pump going South, but you might try a product called..Trans-X.
Draw some of the fluid out, top the pump off with the Trans-X.. drive it.
I've had good luck with it.. but no gaurontees..
Definitely worth a shot though.
Available at AutoZone and the like ?
sagebel
Stock? Pfft!
Albuquerque, NM
I picked up a new pump and tensioner yesterday. Planning on replacing water pump, PS pump, tensioner on Saturday.
Maybe I should replace the harmonic balancer since it is the only original part left on the front of the engine.:dunno
With the move back to Washington coming, I am ok with this stuff. At 205000 miles I can't complain.
Bad Night
Uniontown Ohio
My truck does that sometimes , always if I crank the wheel all the way but sometimes on just minor turns , usually when I'm rolling slow . I just figured it's due to the weight of the motor on the front end and the "grab of the tires " on whatever surface I'm on at the time . Every PSD I've owned has done it .
Brad1103
