Question Post EGR Delete Survey
rustinh1
Kansas City
I had my tech read them to make sure there were no codes. I ran some of Eric's first tunes and wasn't impressed, but as time went along, his tunes have become pretty stellar. This is my 5th 6.0 I've had him tune.
Zmann ARGH
AZ
I bought them a month ago and had to dump them.. mine should be the same as yours? but my AE and insight would see codes ,, I was told all ID does is kill the CEL ?
I wouldn't have wasted 130$ and let him fix it ,, but they didn't respond to numerous tech line was busy =forced to voicemail messages and emails
GAZ4x4
NorCal
You can use a sawsall with a long blade to cut out the scoop. The scoop is huge and really obstructs exhaust flow!!!
I am going to try using a torch to heat up the scoop and bend it over so that it blocks most of the flow going into the egr cooler, I am in California so I can't just delete the egr cooler because it needs to pass the smog test:rant
Here are a couple pics from another site of the scoop being cut out:
vbpgimage.php
vbpgimage.php
Zmann ARGH
AZ
Nice !! I was going to slap an 04 in mine (no scoop) but your way is free lol
GAZ4x4
NorCal
GAZ - when you cut out the scoop - did you get any code lights?
I haven't cut mine yet (pics are from another site) but I think you will only get the CEL (code light) coming on if you totally block it off.
paulpe99
east county
Delete the egr!!
oil cooler project pictures by paulpe99 - Photobucket
that's what i did. and its the best thing, of all the mods, that i did. My truck is now very reliable, as my dd and when i tow my 5th wheel. And no smoke!!! I run pretty clean. except for the up coming smog check in california, its a must for anyone having EGR valve or cooler problems.
late!
Silver6.0
Drinkin Diesel
Riverton Wyoming
I used the MKM customs kit. No problems what so ever. Had it on for about 3 months now. I recommend this kit. No check engine lights, '04.
Jriltex
