ericnourse
First post here with many more to come. I need your help. My 99 SD has popping and thunking sounds under my feet as I turn the wheel when pulling out. It is obviously something to do with a linkage. Answers? E-from CO
duz it do it any other time? might be the sway bar bushing!
Shock bushings maybe ?
It seems to do it on the driver side when I'm going slow. Backing out and turning is when it is most apparent, but going forward too. Up to speed...not a problem. Do I need to get it on a lift to manually move things around. Can I fix this myself? Thanks guys. E- from CO
I'd have to say three things likely, in this order..
most common - sway bar link bushings
next most common - spring shackle bushings
least likely - shock bushings
mostly on the fact you replaced the shocks a year ago..
however, the top bushings may be worn/loose, so again with my mantra..
"Always check the simple stuff first"
