djanzen
Check your upper ball joints. Mine did that when they were shot
I would say check the double cardian joint on the front driveshaft. It is right under your feet. On my 200,000 mile truck I was pulling the trans and found a split u-joint in the Double Cardian. it takes a little bit but it can be rebuilt at home. but if you have your hubs unlocked it shouldent be spinning in 2wd so that might not be it.
