Last fall I replaced all injectors and glow plugs with some from Diesel Care and Performance (DCP) out of Tennessee. I have about 5k miles since and now experiencing some issues.
My configuration is May of 2003 born date, have 90k on engine, manual transmission, EGR delete, 4 inch exhaust, and Juice Attitude tuner. Ran too much bio diesel through the rig and (I assume this happened to me as it was confirmed with my brother's rig) it 'opened' up the nozzles and lost power, he had to replace his duramax injectors.
Called DCP and the salesman talked me into their products and I put them in mid Sept. It ran really good then their glow plugs started to die. By Nov 10, 3 glow plugs stopped working 2 on one side and one on the other bank. Replaced the DCP glow plugs with motorcraft and also replaced the harness over the weekend. Called DCP where they refunded my money, they were good on that side of their word.
Recently, my rig starts great but after it warms up, it will not run right between 800 and 1800 rpm. It doesn't throw any codes (using Torque app with my android phone) and is set up as Diesel Tech Ron recommends. But it struggles and does not rev with the foot pedal and is really slow to respond. So, I changed the fuel filters and which had the 5k miles from when I replaced the injectors. The lower Racor filter, when looking to the inside had brown lines creeping up the filter ribs, so I assume I had some contaminates and did its job. After replacing both filters, it cranked up and we took off. It stumbled some until on the highway and everything smoothed out. Drove about 20 minutes to a known good fuel station and filled up without any issue, put in some Standadyne additive. On the way back, while going up a slight incline, it bogged down and dropped to 55 mph. Reached the top of the rise and it raced back to life and ran great all the way home. I was monitoring the gauges set up on Torque App and all appeared good. Something I noticed, when I let it idle, it struggles... and misses some. But when I roll in and park, the EGT is about 360F and as it idles, it increases to 400 if I don't shut it down.
One other important detail, it has died when lugging or coming out of an idle and the Juice display will blank out and reboot. After reboot, it fires up and runs good. I have shut off the Juice and it still 'acts' the same.
The FICM voltage always stays about 48 but ranges from 47 to 48.5. The HPOP runs about 1600 while going down the road and 650 at an idle. ICP voltage ranges from .2 to 2.2 and stays about .8 at idle. The FICM sync, stays at 1.0. Cleaned the turbo last Sept and replaced the alternator, the batteries test fine; just a farm raised, lose nut behind the wheel...
Here is where I need your input. There are a number of things that are weakness's to focus on...
Is there a chance these new injectors are not performing? Will call DCP to ask what they think but what do you think? What am I missing?
Sorry for the long winded question -
Ken, NW Wy
Ken, NW Wy
