tankerdude
Hey guys!
Some time back I installed the EDAS system being sold by Powerstrokehelp.com.
If you don't know what that is, it's basically a pressure monitor for the cooling system that has an audible alarm if the system rises above 16 psi for more than a few minutes.
When that was installed, I also did a coolant flush. LOTS of fill/drain cycles, each time driving a short distance to make sure the entire system was getting flushed. Also installed a new thermostat at the same time.
AND, just a few weeks ago, I got the Ford parts installed for the high idle mod.
Just last week, I added the RevX stuff to the oil. I was skeptical at first, but thought it would be worth a try. I must say, it has helped the medium/severe miss that was occurring at a cold start-up.
Since then, the high idle mod has worked great on the cold mornings around here. We're talking between 2 and 3 in the morning.
Anywho, this morning it wasn't quite as cold as usual... I'd say around 40. Went out and started the truck. Fired up in what has now become a "normal" fashion. After a few minutes at it's normal idle, I flipped Aux 4 switch and the idle jumped up to 1150 or so.
I got detained in the house for 20 minutes or so, while the truck sat there running at this high idle for the duration.
When I came out and opened the door, I could hear the EDAS system speaking to me. Over pressure has occurred, but the engine temp gauge was just barely above where it is normally.
Popped the hood, and had a look at the degas bottle. It was just a little below where it should be.
I let the pressure off slowly, and poured in maybe 3 cups of distilled water.
I've got the Ford "fix" sticker installed on the bottle, and am running the Premium Gold that Ford recommends.
No odd stuff that I've noticed coming from the exhaust pipe.
Here's the question: Is this thing fixin' to puke it's guts out?
