I heard about something like this from one of my parts suppliers, but I cannot tell you for sure. I think it is in the form of another filter housing and as it spins it flings the oil and uses a thin piece of paper to collect the crud.
Thanks for the information. After reading the website, it is a device that uses centrifical force to capture things that you don't need in your oil. Sounds pretty good for extra measures for the big rig folks I guess who want to go longer between oil changes. I think if I were using this device I would ensure I get my oil samples tested.
I agree with you on that one. Did you say you were running the 15w40 Rotella? I started using Rotella 15w40 a few oil changes ago. So far so good. I also know many PSD owners use Delo and Delvac. Of course I always use the MC FL1995.
sorry was drinkin a shiner(s) @ the airport, couldnt see
the web site but NOW i see "turbine" is spinning at more than
6000rpm...makes me wonder if the chemicals in the oil could
all so but "slung" out too.
blu1ton...yup been using 15/40 (dino) Rotella since the 2nd
oil change....i change it "about" every 5k and its been showing
good test results.
I thought you were happy with the Rotella 15w40. Me too so far.I guess the main thing is to keep the oil/oil filter changed every 5000 miles. With my truck I do the 6 month or 5000 which ever comes first, usually the 6 month period comes before the 5000 mile mark. I would say on average I have around 4000 miles in a 6 month period. Am I doing this right with the 6 month thing or just wait to get the 5000 mile mark each time?
