sasquatch
Hi all. Well I didn't really want my first post to be about a problem, but you know how it goes. I have been having an oil smell coming into the cab of my '07 250 6.0 through the vents for about a month. It only happens if I've been driving and come to a stop, like a red light. It doesn't matter if I am pulling anything or just puttin' around, I still get the smell after I stop. Then after about a minute or so it goes away until the next time I stop. There is no smell if I am moving or if I put the a/c on recirculation.
I have checked all of the obvious things, being that I just had the oil changed I figured someone didn't seat the filler cap all the way or something like that, but no, it's all tight and closed up.
I took it to the dealer and they found nothing, but did tell me that they are going to need to replace my coolant overflow tank and cap because of a pressure build up. No idea about that. Just wondering if anyone has had the same issue. Thanks.
Rob
Rob
