Oil filter fiasco
31 bucks for that amsoil filter ! i get TWO fram (factory spec) filters
at walmart for 28 !
F350DRW1
Waylon Fan
N.J.
True, bush, but you would only get 15,000 max out of the 2 combined. THIS filter will go 25,000! :hail ;)
i only get 10k miles outta TWO filters...7k/7.5k change intervals
dont work for me.
F350DRW1
Waylon Fan
N.J.
Same here. 4-4500 and I'm looking for the drain pail. The 7500 drain interval is a mystery to me. My oil comes out like dish water at 4500 so I try to do 4,000. I would imagine the new 6.4 would be less harsh on the oil now that it doesn't have to fire the injectors.
F350DRW1
Waylon Fan
N.J.
Not to second guess ya, bush, but I believe the filter on the 6.4, according to Ford, gets changed every other change. I read that on a promotional ad about the engine.
accourding to FORD they say the oil AND the filter should be changed every
10k miles on the 6.4L...and thats under the BEST/NORMAL operating
conditions <the oil and filter get changed more frequently, obviously, if the
operating conditions get "worse"....towing, dusty etc>
see the attached maintenance schedule (pdf) that i found.
pete37922
JERZY
i change my oil every 10k and filters every 5k...Amsoil filters and 5W-40 oil !!!
F350DRW1
Waylon Fan
N.J.
Your right, Bush. Its the fuel filters they say are good for 20k. Again, a mystery. They sent out a TSB saying you could go to 20,500 from the 17,500 in the owners manual for the 6.0 but the 6.4 is 20?
