no power and rough idle
rfreese1
manitoba
driving home toinght truck(03 4x4 6.0)was running fine,stopped at lights and it started to idle rough and when i took off no pwer at all barely hit 55mph any suggestions?
Check your intake hoses. One of them might have come loose, resulting in ZERO boost (no power).
fordoor
SDD Member
N. Calif.
Welcome to the site rfreese1. It would help everyone here help you if you filled in your "signature".* At the top is the control panel that allows you to fill in and edit user info.* Mileage,any modifications,etc.* Your truck,like mine, is going on 6 years old now. Have you had the truck from new? Do you have original boost hoses? original turbo?
rfreese1
manitoba
checked intake hoses,allgood changed bothe fuel filters,i heard something about the egr valve but it seems like it is stuck in there pretty goo any suggestions?
Twist it to get it out. They can be a bitch when they are carboned up. Work at it and it will come out. And like fordoor said, go to the USER CP and fill out your signature. This will help us help you. Tell us what you drive and the like.
Dave :)
scottu5
