New Exterior Lighting MODS Complete
Hey Bama,
stylintrucks.com has Chrome Signal bulbs that illuminate amber. Item number RN30206.
Might wana check'm out :dunno
you can probably get those bulbs cheaper @ signal dynamics
or give my your address ill sell you the ones i have...
I tried 'em behind some smoked lens' on my moto guzzi...i was NOT
happy w/ the REDUCTION in over all brightness caused by the chrome'ing
Hey Bama, FWIW ? I put 31>77<s in my Tail-lites.. They're Brighter. Also, I've mounted clear lense, oval marker lights (from a 01 Mountaineer*), centered and just under the SD badges, wired into the T-sigs. Sure helps when changing lanes towing.
* just like the DRW fender/Tailgate marker lights but clear
let me add...it DEPENDS...on the LED...and not ALL LED's
are created equally....some are brighter than others and some
give a WIDER (usually a desired function) beam dispersement.
if youre not happy w/ the 1st one or 2 you try, dont give up...
typically the once you see in autozone,pepboys & walmart (etc)
are NOT the best quality products (in terms of brightness or
coverage).
in LED's you typically get what you pay for.
kenholl
Its my side of the garage
McKinney, TX
Bama, where did you find your smoked clearance lights? I found some on EBAY, but it looks like they come with clear bulbs. No sense in paying for something I won't use. I assume your's are amber? Thanks...
StylinTrucks.com has'm... RN# 264142BK
the cab lenses i have are clear, but you can get them in smoke too.
i bought them at reconaccessories.com. i believe discount power parts, who is a vendor here at SDD can hook you up with some too.
and yes they came with amber bulbs.
kenholl
McKinney, TX
Bama and Big Joe...
Both sites are excellent resources. :thumbs Thanks for your timely help!
