New diesel option
For you two wheel fans:
Engine: Air/oil-cooled turbocharged parallel-twin diesel with twin 360-degree geared crankshafts, dual con-rods per cylinder
Valve arrangement: Apfelbeck eight-valve cylinder head with gear-driven double overhead camshafts, and radial valves with opposed inlet and exhaust tracts
Bore x stroke, displacement: 108 x 78.2 mm, 1430cc
Compression ratio: 16:1
Carburetion: Garrett turbocharger with intercooler, Bosch electronic direct fuel injection, single top injector, 31mm throttle body
Transmission: 6-speed Aprilia RSV1000R gearbox, multiplate dry clutch
Final drive: Belt
Weight: 595 lbs. dry
Claimed top speed: Over 140 mph Claimed power & torque (at crankshaft): 94 bhp @ 4200 rpm, 129 ft/lb @ 2600 rpm:eek:
Link to bike.
Link to review.
Lots of good info in the review.:sweet
Tbar
SDD STAFF/Moderator
Kool............you going to buy one??? :D
Tbar
RenoF250
DungBeetle
California
DaveBen said:
That is a very interesting crank layout!!
Yeah, I am wondering what it gets them. It would probably result in less cylinder wear but then you have the gear cost and wear so I would think that would be a negative. 96bhp from a 1430 cc is not very high performance in the bike world. Still cool though.
I was thinking along the lines of not splitting the cases due to the power pulses with one rod.
On most accounts I would agree with you, but on a first of its kind DIT diesel, its a helluva starting point dontcha think?
FlorWhitfe
