Need a little help guys
94f450sd
certified nutjob
plymouth,ma
doesnt matter AND USE VERY LITTLE spray.doesnt need a whole lot maybe a second or so of squirt should be fine.
Tbar
SDD STAFF/Moderator
it should fire without the glow plugs,not that cold out yet.but turn the key on and wait a good 4 minutes,hit it with starting fluid and see if it runs.if it stays running then id say you need glowplugs.
Starting fluid and glow plugs............. :eek: :eek: :eek:
Tbar
94f450sd
certified nutjob
plymouth,ma
if done correctly starting fluid will not hurt anything.just need to make sure the glow plugs are out and cooled,disconnecting them is the best route.but a 5 minute wait after turning them on should be fine.i do it all the time up here in the winter and when workin on them.
Zookie400
I WANNA GO FAST
wallingford, CT
i do the exact opposite....slam the key directly to crank, no waiting, no giving them time to get hot. no issues yet.
Sport250
Down South, Texas
Thanx Guys
Okay I tried using the starting fluid, Truck acts like it want to turn on but still nothing. I would only spray the starting fluid for about a second then I would wait the 5 minutes as suggested. Should I spray more? Its standard should I try jump starting it? Should I get a match?
Sport250 the first thing you should do is throw the starting fluid in the trash. Using it on a glow plug equipped engine is a very dangerous thing to do. If you were to disconnect the plugs a short squirt might help you out but with them connected you are just asking for trouble.
A set of jumper cables or a battery charger to make sure you are getting enough voltage to the system would be a great place to start.
Sport250
Down South, Texas
Thank You Guys
I was finally able to start the truck while pull starting it. The truck runs and drives great, and restarts no problem. The starting fluid did not seem to work not sure if I didn't spray enough or what. Thank you for the help. I learned a lot from the steps you guys informed me of while trying to restart the motor.
Who has the biggest size down pipe for these models?
I have a twildman chip on my 03 7.3 would this be a good choice for my 94.5
Any other suggestions for added reliable power? Not really looking into a new turbo, injectors, or hpop just yet.
DOC-MX
FOREIGN MEMBER
Celaya, Gto, MX
Thank You Guys
WOW this was a large post, and with a HAPPY END, congrats because your truck is running again :clap::clap: to all of the persons who tried to help you.
For your new questions I suggest that you should open a NEW THREAD. But I recomen a 3 to 4" DP and then a 4" straight pipe. And get DIY stage 1s injectors and the chip.
Good luck.
94f450sd
certified nutjob
plymouth,ma
Good luck.
just go through Beans Diesel Performance he has package deals where you can get guages,chip,exhaust,injectors for short money.plus his customer service can not be beat.i havent dealt with anybody better.
