Napa fuel filter problem?
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
Talked to the mechanic at my dealer today and was informed that the small fuel filter that napa sells is shorter than the ford type and it causes a lean condition that has scored injectors on a few 6.0's I have the napa style in mine and was thinking of replacing them. I noticed that their filter didn't have the fabric outer wrap and the pleats were spaced farther apart. Anybody use Napa filters and what kind of luck you have with them?
albran
Very Junior Member
Ft. Worth
How much do the NAPA filters cost?
Run over to your local International Truck dealer and pick up part #1847170C92 (this is the OEM filter) should be about $40.00, may be a little more than NAPA pos but less than Ford will charge you.
ab
Ironmerganser
Ironmerganser
Omaha, NE
Yeah.....local international dealer is the ticket. The one here in Omaha sells them for $36.
F350DRW1
Waylon Fan
N.J.
While your at the IH dealer get part # 2589259C91 which is the nifty brass HFCM drain plug. About $15.00 and well worth it. :sweet
no-red 6 0
Senioritis
southmetro MN
:jacked
i just had an idear: what does everyone think about a sticky/locked thread that only 'mods' can modify that contains part numbers (fomoco/ih, etc) of common parts we all need. everyone can send in what they have (or maybe look at the thread to make sure we don't over lap) and submit via pm or something to the mods so it can be inputted (is that a word:lmao)
i sure know i can (could) use a few of what is floating around out there and i just copied down the above 2 - ff are due up here shortly....
F350DRW1
Waylon Fan
N.J.
You want an information matrix? I still can't get a reply on where to get a SDD t-shirt or hat. :lmao
f100cleveland
Southern Minnesota
I stoped at napa on my way home today and had them check out if there had ever been any complaints about their filters. None. They even called another Ford dealer to see if they had problems. None again. Still think I will change out to int. or ford filters.
TacoCat
