Mystery vibration (still)
melmount
greensboro nc
i can kisk mine out of od, the rpm's help it. But if i catch it right can still feel a vibration. I had the cct test and #8 ailed. I replaced it. Much better but i still have it but much less bad. I think ones on the way out but good enough to pass. I may have beans sellmy a idm with the 140watt mod. Should kick start the week ones??
i can kick mine out of od, the rpm's help it. But if i catch it right can still feel a vibration. I had the cct test and #8 failed. I replaced it. Much better but i still have it but much less bad. I think ones on the way out but good enough to pass. I may have beans sell me an idm with the 140watt mod. Should kick start the weak ones??
I wouldn't count on it.
I mean, it might help, but somehow I doubt it...
melmount
greensboro nc
I was thinking that if the selenoid part was weak the extra volts going to 140 would help. They passed the buzz test and cct. Beans cant guarantee a fix but they said they have seen 25 hp gains on truck with weak selenoids. Maybe its just not opening enough at low rpm signal. I assume more pedal=morevolts??
sagebel
Stock? Pfft!
Albuquerque, NM
Update: Got the injectors back and installed. Truck runs great with PHP tunes. Just a little tweaking needed.
However, under hard accelleration (empty) or towing (cruising), the truck puts out white smoke. I went in today and checked the injectors with a straight edge. No issues. The shudder/vibration is gone but now I have this new issue.
rammertide07
Rogersvilles, AL
Compression??
first thing that would come to mind is a cracked injector cup..
sagebel
Stock? Pfft!
Albuquerque, NM
No loss or gain in coolant. I have oil leaking from the front side of the muffler. Compression was checked a few months ago and lowest cylinder was at 380. All were between 380 and 410. I will start a new thread as the mystery vibration has been fixed by tuning.
Brad1103
