My TC is gone I need advice!
rickh
Biodiesel Rules!
Bellevue Nerbaska
I was afraid I would hear something like this......
The more I think about it.... if the tranny (Jasper) went out in the 97 not sure what I would do. BTS would be way over kill and I would not stick that much $ into the truck so I can see where your Dad is coming from.
We just bought a 22.5 ft travel trailer. I added the BIG cooler before any bringing it home. Have gauge on order, prevention is the best thing you can do for a tranny. Will change fluid and filter beforing taking travel trailer cross county.
I have looked into a valve body change and will probaly do that, basically its a shift kit already installed and then you just swap out valve bodeis, couple hundered bucks but beats killing the Jasper E4OD!
Rick H...
Diesel Kinevel
97 Stroker
Frederick Co. MD
thanks for the advice guys Ill check the ground richard and I think Im getting him on my side about the suncoast Rick . which is good because I plan on injectors and a bigger turbo eventually......
Diesel Kinevel
97 Stroker
Frederick Co. MD
Found my problem with the gauges.......apparantly I didnt pull enough of slack out of my wire. open steering shaft......I'll let you guys fill in the blank-mad
RacerX
AMERICAN INGENUITY
South Carolina
Have a look at the back of anybodys TC out there. Notice the back ribs all match. Because they are all born Ford. Cut open, stock parts reused or stronger aftermarket oem designs used. The high $ will have stronger redesigned internals and a machined billet cover. Plus 13" diameter for bigger lockup clutch. Low $ billet is stamped and thinner and uses oem guts. Best oem designs are about $600. What Suncoast sells for $1200, others have for $950. Ask how much it weights and you will know how good a TC is. ;)
The custom builders out there know how to make these trannys live with custom machine work that reduces end play and wobble. How well you do with the mass marketer like Ford or Jasper--depends on how worn the core they built yours from was. They simply re-install used parts instead of upgrades or new parts. The wobble just continues and wears out again. Good luck with your Jasper.
PTECH
Jasper Indiana
Rickh,
Jasper does cover leaks. The only leak that wouldn't be covered would be the pan gasket, and that is only after your first scheduled service. You may want to check into that again.
PTECH
Jasper Indiana
Racer X,
For your info, here is the list of updates that Jasper does to the E4OD that he purchased. So much for your theory.
***THIS TRANSMISSION COMES WITH A NEW MLPS SWITCH--CURRENTLY CALLED
THE TRS (TRANSMISSION RANGE SENSOR).***
*** IF THIS TRANSMISSION IS FOR A 1996 E350 OR A 1996-97 F250/F350
WITH A 49 STATE CALIBRATION, THEN THE PCM MUST BE REPROGRAMED. REFER
TO THE FORD TSB # 97-6-29. FOR FURTHER EXPLANATION, PLEASE SEE THE
ENCLOSED TECH SERVICE BULLETIN OR SPEAK TO OUR TECHNICAL SUPPORT/
CUSTOMER SERVICE ASSOCIATES
THE TRANSMISSION OIL COOLER IS NOT INCLUDED. IF THE CUSTOMER REQUESTS
A COOLER FOR A TRUCK OR VAN APPLICATION, THEY CAN PURCHASE PART
NUMBER K405-EL COOLER. THIS KIT INCLUDES THE BRAIDED COOLER LINES AND
FITTINGS. MOTOR HOME APPLICATIONS REQUIRE A LARGER COOLER, PART
NUMBER K4739EL. THIS KIT INCLUDES THE STEEL BRAIDED COOLER LINES AND
FITTINGS.
***THE BRAKE ASSEMBLY AVAILABLE FOR THIS UNIT IS APPLICABLE TO
VEHICLES WITH DIFFERENTIAL DRIVEN SPEEDOMETER GEARS ONLY! IF THE
SPEEDOMETER IS NOT DRIVEN BY THE DIFFERENTIAL , THIS BRAKE ASSEMBLY
WILL NOT BE COMPATIBLE.
NOTE: THIS TRANSMISSION ALSO INCLUDES A TRIPLE DISC CONVERTER.
1. THE CONVERTER WILL RECEIVE A NEW LOCK-UP PISTON, AND A CUSTOM
FORGED FRONT COVER THAT IS .235 (235 THOUSANDTHS) THICKER TO PREVENT
CONVERTER FAILURE.
2. A NEW OVERDRIVE SPRAG IS INSTALLED FOR INCREASED DURABILITY.
3. A 2 ROLLER BEARING IS INSTALLED IN THE CENTER SUPPORT FOR
ADDITIONAL SUPPORT OF THE INTERMEDIATE SHAFT AND LONGER LIFE.
4. ONE EXTRA STEEL AND LINED PLATE ARE INSTALLED ON ALL 7.3 AND 7.5
APPLICATIONS FOR INCREASED TORQUE CAPACITY.
5. A NEW MORE DURABLE STYLE REAR SPRAG IS USED FOR LONGER LIFE.
6. AN UPDATED FORWARD CLUTCH FRICTION PLATE WITH HARDENED TEETH IS
USED. THIS 40 ROCKWELL WILL PREVENT WEAR ON THE TEETH.
Ricksofla
