More EGR?s
Mountaineer
Rome, GA
Okay, I got the dreaded EGR related DTCs today. Just ticked over 40K on the clock.
I've read about servicing and deleting the EGR altogether. I'm planning to keep everything stock for a long while.
As such, is this something I should plan to service on my own or would it be covered under the factory warranty? I'm pretty sure I could do it, but then again if it's a warranty issue I'd rather let them do it at the blue oval store.
I had the local parts store pull and clear the codes as my OBD II scanner couldn't seem to communicate. I've got an actron, but it was a no go.
The DTC didn't come back on the way home, but I suspect the egr is dirty and the codes are coming back.
Thanks in advance for any advice!
atk
Moderator
simcoe, ontario, canada
will be covered under warranty, but might have to pay a $100 deductible....if you have a good dealer that you can trust, just take it in.....BUT, if it just needs a good cleaning, the gasket/o-ring kit is only a few bucks and take about an hour of your time to clean....hope this helps....
Mountaineer
Rome, GA
After some searching, I found a few TSBs. Apparenlty they went from replace egr to clean to now back to just replace. :confused:
I think I'll call the local dealership to run down my options. I'll hope for a warranty freebie.
TacoCat
