twt
I have forgot what the MAP sensor is & what it does. Is there a mod to fool the computer?? My truck bypasses boost when changing gears, am I headed the right direction?? T.Tolle
Could a bad map sensor cause a low boost or no boost at all fault ?
I have a code P1247 and P1248. The truck appears to run ok but now and then it tends to feel heavy, alittle slow to accelerate unless you give it move fuel
