Lost A Front Wheel Bearing........!!!
Tbar
SDD STAFF/Moderator
-mad -mad I have a wheel bearing that is toast!!! -mad -mad
Its loose as a goose...........do I dare drive it to work tomorrow and pick up a bearing on the way home or drive the wifes "mom mobile"??? :dunno
Also, who has a link on the R & R. The one I had book marked is no longer any good. :(
Looks like my weekend is planed.
Tbar
dboyw
Lancaster, PA
Tbar, is the link you had from TDS? If so you can still find it.
http://www.thedieselstop.com/archives/indextranslate.html
Use above link in one page, open link you have in another. Look for the 7 digit number at the end of the stuff in the address bar. Plug it in the link about and you should be good to go. Worked on all my bookmarks, except two.
If this does not help you, then I'm out.
Tbar
SDD STAFF/Moderator
Sorry, Thread ID was not found! :dunno
Tbar
Tbar
SDD STAFF/Moderator
whatabudro said:
You could always try a search over there
:roflmao :roflmao :roflmao :roflmao :roflmao :roflmao
I hate there search mod over there........... -mad
Been looking for 30 minutes now with no luck. :(
Tbar
Frankenstien
Frankestien
South Prairie Wa.
OK... with out instructions its fairly straight forward...once the Brake caliper is off, four nuts off the studs from the rear of the bearing unit, remove the snap ring that holds the hub assembly on, I recomend you get 4 new studs for the Bearing, or you'll have to be a ilttle creative in removing the old ones...I used a pipe wrench... and a large Vise... assembly is just reverse... remember how the dust plate went on... I put mine on backwards... had to un-do what I did.... to get it correct...
Tbar
SDD STAFF/Moderator
I tried removing the studs.........they were tighter than dicks hat band. :(
Beat the crap out of a box end wrench trying to break them loose.
Tbar
Elk
Colorado
If you have or can easily get it, try some PB Blaster. It works much better than WD40.
Brad1103
