Help Needed limited slip in a 02
95talon
Mountainside NJ
ok so i have a 2002 f250 7.3 and i have the open diff. off road and in the snow it suckssssssss haha. one tire just spins. is there a company that sells a limited slip dif for it?
also where can i find a locker for my front wheels, not sure what its called.. would be like limited slip for the front also. something to shift on the fly.
the cheapest and easiest way to get a limited slip for the rear is to get one from a junkyard, around here I can get the whole rear for under 200.
Given that you are in the north and driving on snow and/or ice you don't want a full locker (ie detroit locker) you will want either a good limited slip (detroit tru-trac) or a slectable locker (ARB, Eaton/Auburn Elocker)
On the front in the conditions you're describing you definitely want selectable as you've indicated and ARB is a good option for selectable in the front, expensive but good.
95talon
Mountainside NJ
ok great thanks for the info. in the rear what type of truck should i look for to get the parts that comes with the (detroit tru-trac) or a slectable locker (ARB, Eaton/Auburn Elocker) . thanks again
if you're looking in the junkyard you'll need to know your gear ratio (should be 3.73) you will be getting the factory trac-lock rear which will work adequately for your task at hand.
You'll need the rear out of any 00-04 (you can go back to 99 if you plan on swapping all of the brake parts) F250 or SRW F350
specify that you want a limited slip rear and it'll work for you.
dieselman44641
canton
LImited Slip
I have a 2001 powerstroke 7.3 and I was having trouble with the rearend not locking up when one wheel was spinin I took cover off and realized that the clutches in the rear end were worn out and need replaced the rebuild kit is only $100 Its cheaper than replacing the rear end and it may be a good idea to check it out before replacing it
BIG DUTY
F-250 Care Taker
Traverse City, MI
When i broke the spider gear in my 2000, I replaced the warn out limited slip with the Detroit Tru-Trac. I have been very happy with the Detroit unit. It made a very noticable increase in traction. There is also no extra noise from the rear end around turns. Im impressed by the fact that the Detroit Tru-Trac is all gears and no clutches.
FlorWhitfe
