Leaking Fuel
jarrod1995
Kingsland, Ga
How labor intensive is removing the fuel pump or is it easier just to take it in and get it done. What would you think it would cost for one to get replaced. Thanks.
action4478
Muskegon Mi
I've never replaced one , but I would rather do it myself than to be at someone else's mercy. Buy the part & you'll be able to see what you have to remove to get at it
JOAT
I Found Nemo!
The West Coast
Pull the Y-pipe and filter housing, then the fuel pump is easy. There is a cam follower (or whatever you want to call it) under it. Loosen the pump, then turn the engine till it pushes it up. DO NOT LET THE FOLLOWER FALL INTO THE ENGINE! It happens to a lot of people, so don't be one of them...
dingus
I also have a fuel leak. I took the beast to the vet and they said it was the
pump on top of the engine. The bill will be $650. Is this in line or what?
I could use all the help i can get.
Dingus
JOAT
I Found Nemo!
The West Coast
Wow, $650 is steep, but not surprising from a shop. I'd do it myself, or get some other quotes.
hheynow
Señor Aceite de Soja
Northern California
I don't remember where I got this. -popcorn
FUEL PUMP R&R
1. Remove the turbocharger.
2. Remove the fuel tube banjo fitting bolt at fuel pump .
3. Remove the fuel tube fittings at the rear of the cylinder heads.
4. Remove the fuel tube assembly.
5. Loose the three hose clamps at the fuel pump fittings.
6. Disconnect the water drain hose at the fuel filter.
7. Remove the fuel filter bolts and position the fuel filter forward.
8. Remove the two fuel pump bolts and lift the fuel pump up out of the crankcase bore.
9. Remove the fuel pump tappet from the crankcase bore.
Installation
1. Rotate the engine so that fuel pump cam eccentric is on the base circle to ease the installation of the fuel pump.
2. Install the fuel pump tappet in the base of the fuel pump.
3. Replace the O-ring on the fuel pump base.
4. Install the fuel pump and fuel pump bolts. Tighten bolts sequentially in a crisscross pattern. Tighten fuel pump bolts to 26-37 N-m (19-27 lb-ft).
5. Install the fuel filter and connect the water drain hose.
6. Connect the three fuel hoses at the front of the fuel pump.
7. Tighten the fuel hose clamps.
8. Install the fuel filter retaining bolts. Tighten bolts to 33-52 N-m (24-38 lb-ft).
9. Install the fuel tube assembly with new seal rings at the rear of the fuel pump.
10. Loosely install the fuel tube fittings at the rear of the cylinder heads.
11. Install the fuel tube banjo fitting bolt at the fuel pump, tighten pump bolt to 20-24 N-m (15-18 lb-ft).
12. Install the turbocharger.
13. Tighten all fittings securely.
RoReRi
Verona, NC
I've done mine, with out removing the turbo. Its just that the Banjo bolt is one of those 45 minute bolts. Also it helps to have grease and diesel fuel on your hands so they can slide around so you can start the banjo bolt. I think Baz has a write up on his site on how to do it step by step.
Its not too bad. It was the first major thing I did to my truck and never having a diesel before I was right stoked that I did it.
Took about 6 hours...
Only thing happend was a small hose clamp fell into the hole where the tappet goes, down into the bowels of the engine... its still there.:oops:
Check out my post on the "other site" from about 2 years ago.
Its kinda of funny now, but at the time, I was sh*&* my pants...
RoReRi
jarrod1995
Kingsland, Ga
"DO NOT LET THE FOLLOWER FALL INTO THE ENGINE! It happens to a lot of people, so don't be one of them"
Whats this follower that people are talking about, is there a trick on it not falling in, Thanks.
Jriltex
