Tail_Gunner
CRJ & ERJ A&P Mech.
A couple of years ago, I had to do the rear barkes on the beast. The right rear was clearly dragging and making a bit of a mess of the rt rear wheel. I bought rear rotors and pads thinking "piece of cake". Well as it turned out, the slider pins were siezed and I couldn't get them loose for the life of me. Following good mechanical practice, since I had to replace one rear caliper with bracket, I did them both.
In the days since I got back from moving our daughter to Nashville (and my coolant temp gauge adventure), I've been hearing the dreaded metal on metal sound in ever increasing volume. So I go buy front rotors and pads, again thinking "piece of cake". I put the front axle on the jack stands, get the wheels off and then plop my butt on the little padded geezer support with the caster wheels and get to it. (Note word for word cut & paste from previous paragraph): Well as it turned out, the slider pins were siezed and I couldn't get them loose for the life of me.
So here it is 4 pm Sunday afternoon. The only place in town that is open is Advance Auto parts, seller of quality coolant temperature sensors. They have the calipers, but not the brackets. Since the slider pins are siezed in my old brackets, my calipers & brackets are pretty much now a one piece paper weight. So there is no reusing the old brackets, I new new ones.
My advise to everyone: if you ever need to do your brakes, just buy rotors & loaded calipers with brackets and get it over with.
