rammertide07
Yesterday, I noticed my truck was a little trouble starting. So this morning when I went to crank it....it barely had enough spin to get it started. I'm going to go out at lunch at start with the battery terminals. I have a couple of fused wired coming off the positive terminals....800watt inverter on my passenger battery and my gauges and auxillary back-up lights on my driver side.They get kinda crusty when you have connections like that on them.
Also the other day, I took off just the posotive battery cables to reset the computer. Is that ok?...or should I have taken off the negative cables as well?
On my way to work, the voltage gauge on my dash was reading high and my radar detector was showing about 13.5v. I'm going to check the voltage at lunch before I start it to see if the batteries have drained any. If I cant get the truck started, I'm going to take the batteries off and take em up to the parts store to have them tested. If they check out ok, I'm going to try getting a starter. My uncle's 99 7.3 starts up much faster than mine...maybe twice as fast. It has been like that since I can remember.
So if I do buy a starter is there a "better" one to buy? And I've looked at some already...does it matter if it is 2 or 3 bolt? Thanks for the advice guys
