Is it ok to use Synthetic oil in a 2004 with 80,000 miles
bigmike33
Kitimat, BC
I have a 2004 F350 with 80,000 miles on it. Is it ok to use Synthetic oil ? I am using Rotella 5- 40 right now. What would recommend for my automatic transmission and diffs as well. I like Synthetic. I also have a module, 4 inch exhaust, and an AFE airbox. I run it hard sometimes and place a lot of importance on my fluids.Any ideas?/ CHEERS MIKE
NASCAR Mike
Richmond VA
From what I understand Shell Rotella 5W40 is synthetic. Shell Rotella 15W40 is NOT synthetic.
I am not sure what trans you have (manual or auto) but if it's an automatic then you must use Mercon SP which is already synthetic.
The rear end uses 75W140 and I use Mobil 1 Synthetic there.
You can use synthetic in your truck with no problems.
dlonno
BeerHunter
San Diego
I hope so, I'm switching tommorrow to Amsoil 15w-40. I have 35k on my 05.
NASCAR Mike
Richmond VA
I only have 18k miles on my 05 X and I still use regular 15W40 Shell Rotella.
At 20k miles I will assume the engine has broken in and I will start to use synthetic myself. I plan on sticking with Shell Rotella though.
VALKYRIES
Fort St John BC Canada
synthetic oils and grease
Make sure the the oil will take the pressure that your hydraulic actuator system operates at. I know of one syn oil that won't operate at that pressure.
F350DRW1
Waylon Fan
N.J.
Which one shears down that quick?
