Help Needed Is it my TW chip?
ward cleaver
Californication
I'm sure this problem is the switch or a loose connection at the chip. Now there is no difference between my stock position or any other.
ward cleaver
Californication
latest update: I unplugged my pcm from the harness and got a new/better EBPS eliminator and now the truck is back to it's old bad fast self!:tounge
The chip is working fine, everything is groovy!
ward cleaver
Californication
Ok, It definitely was NOT my TW chip! The problem persisted, then...
2 years ago I bought locking gas caps for the truck when diesel hit $5/gal.
They were not for a diesel and there definitely IS a difference.
I drilled 1/4" holes through the gas caps, converting them to diesel fuel caps.
WOW what a difference it makes when the tank is not under a vacuum.
It even runs better in stock mode!:D
I tried to buy a locking fuel cap from Ford for my truck and they said that it is not made. I did not know the difference. Guess I will be buying a gas cap for my diesel. :)
strokin'_tatsch
death row inmate #7
Austin, Texas
glad to hear you got your fixed up!!! i got mine fixed as well but not as cheap as you did. mine actually turned out to be injectors. mine was bleeding off HPO from the poppets in the injectors. haha
