Interest in a Full Trim Replacement Pillar Pod?
Would you be interested in purchasing a pod like this if it were offered?
  • Yes
    Votes: 25 89.3%
  • No
    Votes: 1 3.6%
  • Whats a pillar pod??
    Votes: 2 7.1%
  • Total voters
    28
MrTailLight
Edison, Ohio
Crumm, i like that pod set up you have there. where did ya get it? i might stick with that over the dash mounted!
hheynow
Señor Aceite de Soja
Northern California
PSDfreak said:
Anyone know of another pod that clips on rather than you drill and use those dumb plastic "Pine Tree" deals?
FYI, dumb plastic "Pine Tree" deals are commonly know as push pins.
Tx_Atty
Master Baiter
Fishin'
My pod came with the same push pins. While installing they were misplaced so Antonio and I decided to use the screw holes on the stock cover. I just drilled those two holes in my pod and ran the screws through both. It works just fine and you dont notice anything different looking.
rickh
Biodiesel Rules!
Bellevue Nerbaska
A peice that large would be cheap to pop out of ABS, maybe around 2 bucks each by the 1,000. The problem is... THE MOLD. In USA it would be 15k-20k. Overseas maybe 5-6k.
Just the tool steel to make a mold from for my column mount was 3,500, then all the lay out and machine work... 22k in US. Never priced overseas, just dropped it.
I would not buy a replacement insted of a cover. I think cover ups look fine.
If you got the time, you can hand lay one out of fiberglass.
Rick H...
Ricksofla
