Redrig
Rig Monkey...
Hello fellow Diesel drinkers....I am about to change out my injectors….I was wondering if there are any tips or warnings you may have. before I take the next step, I have been told to ensure oil does not drip down into the cylinders, but not how to prevent this (I would assume dropping the oil out, but is that enough)...at the moment I am in the process of changing out my water pump and a few other minor things, two of my injectors are flashing up codes**, so I am changing them out while I have the hood open….any and all tips and solutions would be greatly appreciated, Thank you!
**P0269 Cylinder #3 Contribution/Balance :When maximum/minimum pulse width adder exceeded and cylinder does not converge a fault is set.
**P0275 Cylinder #5 Contribution/Balance :When maximum/minimum pulse width adder exceeded and cylinder does not converge a fault is set.
