Tail_Gunner
CRJ & ERJ A&P Mech.
I never did ask...
is it throwing heat?
Yes, it's throwing heat.
After some highway driving, the upper radiator hose is hot, but not so much since I can grab & hold it. The coolant filter however, which taps into the water pump flow prior to the t-stat, is hotter than hell.
I can't work on the truck until after I get back from a couple of appointments today, but I am very ecouraged that my issues will be resolved today.
Yesterday when the OEM temp sensor came, I did a little experiment. I heated some water in the micro wave and took the water and sensor out to the truck. I unplugged the wires going into the coolant sensor and plugged in the new Ford sensor. I then put it into the near boiling cup of water. I got into the truck and turned the key on and watched the temp gauge rise past the cold mark and into the normal range. THIS IS A VERY GOOD SIGN!
Last evening, I did another little experiment. Again I heated some water, hooked an OHM meter up to the sensor. I then dropped the temp sensor and Mrs TG's cooking thermometer into the hot water. As it cooled, I recorded resistance & temp readings, putting those readings on a sheet of graph paper. I plan on doing the same with the Advance Auto parts sensor when I get it out of the truck. Then I can compare the temp/resistance readings. I am highly confident there will be a big difference. Enough of a difference where I should be able to show it to Advance auto parts and say "This is why it don't work right".
Stay tuned.
