melmount
Just checkign for info, If a 7.3 dioes not start, we can unplug the icp? that will set itto default. If it starts then, replace the icp? If it still does not start, it could still be injector not getting enough psi, right?
bad hpop?
do hpop's fail? Or is it all mechanical there? Example, just loose an o ring or something? Which causes pressure loss? What can go wrong with an hpop?
thanks
bad hpop?
thanks
