if a 7.3 does not start??
jman18et
moncks corner, sc
got it. i have a question about that. my 2000 7.3l shut off as i was driving down the road. i tried after i pulled over to restart the truck and it would only crank over but not start. a friend of mine who has a 6.0 psd. came and told me about that sensor. we disconnected it to see if it was the sensor or the hpop and it started normally but after a random time it will just turn off. like i turned it off with the key. what would be your best guess. the hpop or pressure regulator. or should i just replace both at the same time
dpantazis
#12
under the cheddar curtain
what sensor did you unplug?
you should read the CPS thread.
Cam Position Sensor does go bad, so often there is a recall on them. keep a spare or two around.
rotorholic
Dallas TX
I had the same problem, Truck would run and shut off, One day it didnt start anymore. It was the darn CPS.
