97powerstroker
i got the bolt that attaches to the centerlink right out,but the one attaching to the frame wont budge,it spins in the bushings,feels loose,but will not come out,ive been tryin for hours and im fumed,help please
nevermind i finally got it,its four the steering on my lift,it connects to the centerlink.i had to cut the bolt.the bolt and the steel sleeve inside the bushing rusted together,it sucked.i replaced the centerlink,idler arm bushings and the inner tie rods,and the front end of my truck will start shaking bad around 50, but once i go over or under it,it almost tottaly stops,which this was why i replaced alot of these parts in the first place cause they were worn,but it still does it,im guessing an alignment now
