idler arm
97powerstroker
north port,fl
my gear ratio is a 3.55,which i think is bad for towing already,when you throw bigger tires on,its like having a 3.14 gear now,i want to know how much this will affect my towing capabilities?
Big K
SDD.com Hacker/Admin
Dallas, Texas
Sorry, didn't understand what ya meant.
Yea, the OEM tires are like a 31.5" size (aka 235/85 or 265/75), meaning, when you throw 35" tires on it, your final rear end ratio will be close to 3.20 Gears.
Yes, it will need more PEDAL to get it going, but it will still pull it :D
If you are going to be pulling ALOT, I would suggest get some 4.10 gears to swap in for sure.
:sweet
97powerstroker
north port,fl
hopefully,my od is weak on my 5 speed,i can barely accelerat on highway with 2k in overdrive,1st thru 4th is great,od is like a turtle,:confused: why is od so weak,and will i burn more gas tyin to run od workin the engine hard or runnin 4ht gear at 2700 rpms? which is better
Big K
Dallas, Texas
Yea, if you are towing with 3.55 gears, more than likey you will need to allways tow in 4th.
OD isn't weak, you just don't have towing gears ;)
97powerstroker
north port,fl
:thanks thanks for all the info,some of you guys no to much about these trucks,lol, better for the rest of us though:hail ,have a good day
It is the load rating of the tire that counts, not the truck. What are the load ratings of the tires?
97powerstroker
north port,fl
umm not sure,i just want to be able to tow a heavy load atleast 70 mph,is that to much to ask,just kidding,ive got tow fever!i need to tow something heavy,im just curious about what my truck can handle doing 70 mph,ill have to run 4th
FlorWhitfe
