hub bearings?
georgetown texas
I no longer use the auto hubs so could you theoretically remove the vacuum lines and install grease zerks for the bearings?
bigrigr
Real trks hv 3 pdls
provo, utah
Sounds interesting, I thought that these trucks had unibearings, or sealed bearings? In other words there not serviceable. the vacumn actuates the hub inside the wheel bearing assembly, but not through the bearings themselves. I don't think you would do any thing but lube the hub parts really well. Most of the time to much grease in the hub parts means stiff movement/no movement which = no 4 wheel drive when you need it most. ;)
I know you can't lube these bearings. They are a one shot deal. Install them, and burn them out, replace.
Tbar
SDD STAFF/Moderator
Wasn't there some talk at one time about pulling the abs fitting and squirting some grease in there?
Tbar
platinum01
Willis, TX
This is intresting, I am with you Dave I thought they were sealed. And when they make noise you change them out.
I have a new set on order and when they get here I will check out all of these rumors. I will get back to all of you on this.
