I made it home
but that is about all I have good to say.
I had a 1 gallon jug in the bed and it didn't look good. It was completely separated like the jar at home. When I fired the truck up I rocked it back and forth for a minute to re-blend the fuel in the tanks. It seemed to mix back up in the jug so I figured it would mix in the tank.
I then let the truck warm up until heat was coming out the vents and headed for home. The drive home was uneventful without a hick-up. I should have pulled the filter and took a look when I got home but I was tired and wanted to go to bed.
When I headed in the house I took a look at the test jar and really didn't like what I saw. The separation was down to about 3/5-2/5 but the bottom 2/5 was about as thick as syrup. I tipped the jar up the stuff on the bottom didn't move. The jug in the bed didn't look near this bad so maybe smaller quantity's react differently than larger quantity's. There is no waxy looking crystals in the fuel like all other gelled fuel I have saw so I am not sure what this separation is all about. Most of the gelled fuel I have ever saw has been frozen like Jello and full of crystal looking chunks that plug filters. This fuel that I have is just separating not really gelling. Very strange.
I have sent Howe's a couple of emails but they have failed to respond. There guarantee is that the fuel will not gel and it has not so I guess they didn't lie but the separation has me concerned. I have used Howe's for quite some time as a lubrication additive but am starting to second guess the winter protection of it. As long as the truck is in motion the fuel will not separate as it takes very little motion to mix it back up but when it sits it separates.
I normally run #1 so gelling is not a problem but since I had this number 2 I thought it would be worth a test. Still up in the air if the test was a pass or fail. It didn't gel but I don't like the look of the separation. Next time I fill up it will be number 1 fuel and I am going to pull a sample and see what it does with and without Howe's. I am also going to set out some untreated #2.
