how much oil do you consume?
I'm just wondering why some would burn or loose oil while others don't.
Thats just the nature of the beast.
  • Driving style
  • maintenance procedures (especially oil, oil filtration and air filtration quality)
  • how the engine was broke in
  • has the engine ever been hot
  • etc etc etc...
hdjeff
Medina, Ohio
ok, just curious first thing i did was make sure i didnt have the dipstick that matched the one that read 2 qts low. overall i dont normally burn oil, only when the engine is very cold and when i dont plug it in below 40. it will smoke a little and smells a little oily. after warm no smoke at all. probably going to do glow plugs in a little bit.
Mine is usually on the add mark when it is time to change it at 5000 miles. I think once my engine gets broke in the consumption should decrease :D
roosterdiesel
Earl needs B100
Amarillo,TX
:nutkick: :nutkick: Thanks Richard!
You guys suck....mine uses 2-4qts per 5K. I've got 125K on the clock but have been dusted from my old AirAid intake coupler that was too small and letting the hose work loose. Then I realized the filter was pin holed.:doh:
Ricksofla
