how much boost???
96EDGEpsd
Welding/Fabrication
New York
well this is an update on the situation...i went to the hardware store and got all new hose larger diameter, there are no leaks from the T-fitting to the gauge, and egr valve is deffinatly open still nooooooo boost...i dont get it
JOAT
I Found Nemo!
The West Coast
I can get well over 15 psi with a mostly stock truck.
What other symptoms are there? Smoke or no? Lack of power?
- Try unplugging the MAP sensor and see if any change in performance.
- Unplug the ICP and see what happens.
- Keep a fuel gauge on it while driving and see if the pressure drops under load. It should not drop much if any. You can use a cheap 0-100psi electric oil pressure gauge to make it easier to see in the cab w/o risk of broken gauge causing fuel leak in the cab.
whatabudro
Launched
I still think its the line, it has a KINK in it somewhere, not a leak.
96EDGEpsd said:
brass fittings dont think im smashin those...
Have you pulled the turbo inlet hose yet? What is the condition of your compressor wheel? Has the turbo been "dusted" prior to you owning the truck? I will agree, even with stock injectors, an intake, chip and exhaust should easily net you 20+ psi boost. I dont want to sound like a broken record just becaust I myself just went through this but....Make sure you dont have a turbo problem.
whatabudro
Launched
96EDGEpsd said:
just pulled the inlet hose to the turb, seems perfectly fine no wiggle spins free and smooth...hows this look? :confused: View attachment 815
Your hose and hose barb are the source of your problems. You are (IMO) blowing past the hose barb when you are making the boost. Is that soft tubing? Surgical tubing? You may be able to fix it with a clamp, but I would run hard vinyl tubing, that uses compression fittings, like this:
Ricksofla
