Houston, We have a problem!!!!
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
First test drive after replacing my donut exhaust gaskets, when I put my foot down, I hear a sound that, to me, sounded like a PHSSSSST. I figured it was the new donut gaskets not sealing. A suspicion backed up by the decrease of top end boost and a lack of exhaust brake effectiveness.
The next day, I notice I'm blowin white smoke like a BBQ pit. I guessed that leaky donut rings are causing a lack of drive pressure to the turbo and the truck is running rich because of it.
So today, I decide to take a good sniff of the white smoke to determine if it smells like fuel. Nope, it smells like burning motor oil. On closer investigation, I notice I have oil in my exhaust pipe. :eek: :eek: I stick a fingertip in it and take a sniff. It ain't fuel, but oil. I'm hoping that it's oil coming from the turbo center section leaking out the exhaust side. Since I have wet oil in the exhaust pipe tip, that's what I'm praying for. I would think that if it were coming from one of the cylinders, it would pretty much be burned away. As it is now, I'm only about 1 to 1.5 qts low on the dipstick.
So tomorrow, I'm going to pull the turbo (I'm starting to get way too familiar with this procedure.) and pray that the up-pipes and baby's butt are dry on the inside. A turbo is a lot cheaper than an engine rebuild.
bonestroker
stroke it if you got it
In the field
thats what mine was doing. So took it in to have it looked at, lost the compreson on num 2 cyl
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Another reason I'm suspecting the turbo vs engine problems, It's running really, really smooth. I think if I'd lost compression on a cylinder, I'd have a "miss" when it ran.:dunno
Got Diesel
Engineering College Boy
Missouri
I would be thinking turbo Kent. I still haven't gotten my donuts completely sealed up yet, haven't had any damn time to do it.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Just got off the phone with Bean. Bean said it sounds like I broke a turbo shaft. He said he recommends a F17250 donut gasket from Car Quest.
He also said his D66 supply issues from last summer have been resolved.
I've got a PASTY in the oven for lunch.
After that, it's surgery time on the truck.
"Dear Lord, please let it be a turbo and not something in the engine, Amen"
fordtrucker4life!
I work with waste
SE Michigan
Good luck. I hope it is something that can be fixed soon and your truck isn't down and out for a while. The cold front could be bringing some white stuff sometime. It always snows around opening day rifle season.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I hear hear ya!!
Trying to fix a truck outside in a snowstorm really, really sucks.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
THANK THE LORD!! MY TURBO TOOK A DUMP!!!
The good Lord answered my prayers!!!:woo :woo
I don't have many religous moments, but the moment I pulled the turbo out of the truck, was one of them.
I got the turbo off (in only about 45 minutes at that, is that a record?) and the inside of the babies butt had nothing but glorious, black, nasty, DRY soot!!!
The inlet of the turbine/exhaust side of the turbo was dry too!!:thumbs
But the outlet of the exhaust side was NASTY, thickly coated with a sooty, oily, gooey residue. The turbine wheel had about 1/4" to 1/2" of side to side movement, just a TAD excessive.
If you're thinking, why is this looney-toon so excited about a trashed turbo?
For two reasons:
1) Turbos are a lot less expensive than new engines.
2) I can get a D66 from Bean's and not get b*t*hed at by Mrs TG. :thumbs
This is a good day in the TG household!!!
Now I just have to get my exhaust brake off the old exhaust side, about all of the bolts are siezed. I better go pick up some more wheels for my pneumatic cuttoff tool.
