hhorlings
What's the normal range for oil temperature? While towing 9000 lbs, oil temp can climb to 230 degrees with engine coolant around 220 degrees. Clutch fan locks up around 216-218 degrees. 2007 F250 Powerstroke with Banks Powerpack System. Have had heads and gaskets replaced (with ARP studs) for outgassing through coolant bottle. EGR replaced during same period. Oil temp seems to always be between 220 and 230 while towing. Seems kinda high to me although this could be normal. Looking for feedback. Any help is appreciated.
