desert50eagle
Let me start out by saying that I know my way around fasteners, nuts, bolts, drills, taps, threading equipment and the like. I have been in the building trades for almost 12 years. I got into the trade right out of high school. I also enjoy wrenching on my personal vehicles when i have the time. I do consider myself more mechanically inclined than a lot of folks. However...I am having a hard time with the drain plug for the HCFM. It got completely stripped (I only finished the job started by someone else)so naturally I figured(along with some help) that an ez out would be my best bet. This afternoon I tried to remove the stripped screw. I first sprayed on a little penetrating oil to help and then successfully drilled and got the ez out completely seated. I tried the largest 2 piece ez out I could find. When I tried to remove it... The whole assembly kept trying to fly off of the frame rail and the brass screw refused to budge. It kept on like this for about 5 seperate attempts until (surpise,surprise) The ez-out broke off. Now the threaded end is locked into the screw and I am left with a broken piece of the shaft. This screw feels like it is welded in. I have the upgraded hfcm screw waiting to go in and as of now their is no fuel leaking out from around the ez-out(as of yet).
My questions are as follows:
1. Can i use compressed air or something similar to try to "FREEZE" the screw- Hoping that it contracts and i can use channelocks on the broken ez out to remove the screw???
2. I dont know the last time the hfcm was drained (i bought it used) what will happen if the water in fuel light comes on and i havent yet managed to remove the screw?
3. If i buy a FASS or something of that nature will it replace the whole hfcm assembly/unit or are they to be used in conjunction with one another?
4. I really would like fix this without taking it to a dealer...Is it possible?
ANY HELP would be greatly appreciated as this is my daily driver. She is an 04 350 srw supercab fx4 auto with 44,000 on the clock....Please help! Thanks in advance...
